Machine Vision
Rearrange Column Header in Vision Builder Datalog
How can I rearrange the column header of data logging? For example, I want the arrangement to be 'No.' - 'Tip Diameter' - 'FA Left' -'FA Right' - 'FA Average'.
Attached here is the example of wrong arrangement.
(1,584 Views)
I would like to recommend to try "Set Variable" Inspection Step prior to logging. Insert it before Data Logging, then create variables from Inspection results, may be give the names like "1-No", "2-Tip Diameter", "3-FA Left" and so on and then use variables instead, and may be they will appear in other order as required (just an idea).
(1,516 Views)
