04-16-2019 03:34 AM
I have a problem with the IMAQ Detect shapes VI (in particular with detecting ellipses).
I am trying to fit an ellipse to an elliptical droplet after applying a certain threshold to the image, but the detect ellipses VI always only produces circles as the best and only result. The used images show a relatively low resolution owing to the camera - maybe that's the reason.
I tried all input parameter combination I could think of. Does anyone have an idea or solution to fix this?
I will attach my VI and an example image for clarification.
Thank you very much in advance.
PS. please ignore my weird event structure for clearing the stored images - I am pretty new to labview and couldn't think of a better way to clear memory without the program erasing them as soon as its done with ellipse detection.
04-16-2019 05:45 AM
Yes, the resolution is the problem.
With 10x upsampling (using IMAQ Resample) the results much much better:
(you will need to divide results by 10 to get back to the original size, of course)
Andrey.
04-17-2019 02:45 AM
I suspected as much, but wanted to avoid data manipulation due to Pixel interpolation if possible.
Seems like I have no other choice.
Thank you very much for your help Andrey.
