Machine Vision
Pattern recognition in bayer and mono cameras
It's experience-related question about cameras and image processing.
I have a laboratory setup. Under some simplifications it looks like a red ball rolling on a white table (the real setup is shown here https://www.youtube.com/watch?v=kyvW5sOcZHU). A computer vision system should measure X and Y positions of the ball.
For now I use a color camera (with Bayered output) and I find the ball by applying a simple color filter (InRange for R, G, and B components) to the frames. It works, but I would like to increase precision of the measurements.
Question:
Would accuracy of measurements be better in a case I used a mono camera with the same parameters as bayer-camera?
I guess it should be so in a perfect case, i.e. when the ball is definitely highlighted on the frames. But in reality brightness filter usually works worse than color filter. On the other side I can change the shooting conditions, because this is laboratory setup. I can change the color of the objects, I can change lighting.
(4,949 Views)
Theoretically i think it is more precise, due to the absence of the debayering filter. I think it's better to choose complementary colors for the ball and the background (black on white?).
(4,938 Views)
Edges are a lot fuzzier with color cameras due to bayer filtering, but I suspect finding a large circular object works pretty well due to the large number of edge pixels.  Theorectically, a grayscale image would work better because the edges are more clearly defined.  When using color, I would probably use the hue and saturation images with any color other than red.  Red's hue is zero, which is the same as grayscale.
Bruce
Bruce Ammons
Ammons Engineering
(4,935 Views)
Thank you guys for the answers. According to your comments it's better to use grayscaled camera, and shooting conditions should be as good as possible.
I thought about drawing the ball by fluorescence paint. I can install ultraviolet lighting so that the only ball re-emits this light. So, the camera can see the only re-emitted light from the ball and reflected from other objects this re-emitted light. The ball should be much brighter than other objects. What do you think about this?
(4,930 Views)
Probably overly complex.  I would stick with one of two approaches.  Black/white contrast between ball and background, or paint the ball with a color with a significantly different wavelength than the background, and use a color filter on the lens so you only see the ball.  Don't use a white background in this case, because part of the white wavelength matches the ball color.
Bruce
Bruce Ammons
Ammons Engineering
(4,867 Views)
