11-10-2017 07:01 AM
I'm trying to create a system based on Linux that can acquire data from a camera through a PXIe-1435. I wasn't planning on using LabVIEW for this, but instead wanted to make a small custom program in C++. Is there any way to address the frame grabber with this setup?
Attached is an image of the VISA control program, with the listed devices. My three ADC cards come up under PXI devices, and then there are 4 other devices which are shown as 'serial instruments'. I suppose one of those must be the frame grabber I want.
Is what I want possible?
Thanks!
Solved! Go to Solution.
11-13-2017 02:26 AM
Ok, never mind. Apparently the targets I'm seeing are other devices on the network, and NI-VISA isn't compatible with PXIe at all, so doesn't see anything. Very disappointing.
