Hello Eclim
I am assuming that you are referring NI VDM (since you mentioned VB and C#). Learning basics of VDM is not rocket science. I recommend you to get started by
> Exploring NI Vision Assistant - Open images and try some functions.
> Then start going through NI Vision Concepts Help (.pdf /.chm file), which contains the concepts behind image processing algorithms.
> Then understand how image buffers and different image types are handled.(Use NI help - Ctrl + H)
Hope this helps !
-Rahul
Hit KUDOS for Thanks
