10-02-2019 10:17 AM
I was trying to upgrade an old imaging program from 2015 to 2019.
I recompiled the 'Installer' package from LabVIEW 2019 with all the suggested driver installers, IMAQ, IMAQdx, IMAQ IO, NI VISA, etc, and installed it in the computer.
I thought this would be just another regular upgrade, but this error message kept showing up.
Can someone please provide some idea what causes this error? Thanks much.
10-03-2019 09:28 AM
Hi Meng Hui,
Thanks for your post. This is a known issue (bug 200473) with NI-IMAQ 19 and will be fixed in 19.5. It only affects the IMAQ Grab Acquire and IMAQ Copy Acquired Buffer. The workaround would be to use the Compatibility API - IMAQ Grab Acquire or IMAQ Extract for the time being until 19.5 releases which should be around end of October.
Hope this helps
10-16-2019 02:54 PM
I have this problem as well. Waiting for a fix. Unfortunately it means having to uninstall NI-IMAQ 2019 and reinstall an old version and recommending our customers avoid installing NI-IMAQ 2019 (some already have, and encountered issues).
NI-IMAQ 2019 took hours to install and it's going to take hours to get the PC back to a usable state.
This seems to be a huge oversight, such a basic and heavily used function that should've been caught in NI's testing before release.
10-17-2019 08:45 AM
Totally undertand. It took me two days to try everything possible, until I realized that this might be a NI issue. And It is. I did not receive any notice on this one. I would agree NI vision team messed up this time.
10-30-2019 10:48 AM
Any word on when the update is rolling out?
10-30-2019 11:04 AM
I also checked for it this morning and it also wasn't available. Since our customers are complaining they can't use their cameras, I set up a PC with VAS 2019.0 (since I don't want to put it on my development PC) and I'm noticing a lot of quirks/bugs in MAX as well. I hope they're fixed in the new version.
They are:
There are probably others but that's what I've found with the limited testing I've had.
Bruce
10-30-2019 02:15 PM
Vision Development Module 2019 SP1 should be available for download sometime tomorrow.
10-30-2019 02:18 PM
Hopefully you also mean that Vision Acquisition Software (VAS/NI-IMAQ) will also be updated tomorrow.
Bruce
11-01-2019 07:12 AM
I guess it didn't get released yet.
https://www.ni.com/en-us/support/downloads/drivers/download.vision-acquisition-software.html#305518
11-04-2019 06:51 AM
Okay, it's there now. Downloading and will begin to test it out.
https://www.ni.com/en-us/support/downloads/drivers/download.vision-acquisition-software.html#329473
Thanks!
