03-05-2019 05:07 PM
I am trying to interface to some FLIR IR GigE cameras using NI-IMAQdx version16. I can make everything work nicely in 32 bit mode, but when I compile for 64 bit the program doesn't work. Can you tell me if IMAQdx 16 supports 64 bit windows 7? All of the NI-IMAQdx software seems to be in the Programs (86) folder, i.e. 32 bit software. Specifically when I write to registers using 64 bit IMAQdx and then read them back, the results are garbled.
How can I determine if the proper 64 bit driver for NI-IMAQdx is installed and working. NI-Max appears to be a 32 bit program so of course it works.
Thanks for any help.
Dan
03-05-2019 05:13 PM
Hi Dan,
Yes, IMAQdx supports 64-bit Windows 7. Can you sanity check 64-bit LabVIEW and make sure you can acquire with one of the examples there? That's how I would determine if everything is set up correctly for 64-bit applications.
Katie
03-06-2019 10:20 AM
IMAQdx installs a bunch of C examples here:
C:\Users\Public\Documents\National Instruments\NI-IMAQdx\Examples\MSVC
They do compile and run properly for x64 on 64-bit Windows. Have you tried those as a starting point?
You mentioned you had an issue reading/writing camera registers? Can you share a snippet of code that fails?
