12-04-2013 04:19 AM
I'm trying to use a USB camera (thorlabs DCC1240c) with the "Grab and save to AVI.vi" example.
When I run the file i got "NI-IMAQ: The passed in interface or session is invalid".
I checked in NI MAX and the interface name of the camera is cam0 and that's what I entered in the "Interface name" box in the front panel.
What's the problem ?
Thanks in advance,
Gabriel
12-04-2013 05:30 AM
12-04-2013 09:18 AM
it is in NI-IMAQdx Devices.
How can I change it then ?
Thanks for your help
12-04-2013 10:03 AM
12-05-2013 01:53 AM
Thanks a lot, it works fine now 😉
Have a nice day.
Gabriel
12-05-2013 02:10 AM
07-07-2016 11:04 AM
01-18-2025 05:36 AM
I used LabWindows/CVI and got the same error message when use a USB camera (Logi C270 HD WebCam).
I can see the camera under Devices and Interfaces as "cam0".
Function call imgInterfaceOpen ("cam0", &Iid); will return 0xbff60015 error message.
The passed in interface or session is invalid.
01-18-2025 05:51 AM
I can't find NI-IMAQ, NI-IMAQdx setting in MAX.
01-18-2025
08:00 AM
- last edited on
03-26-2025
11:08 AM
by
Content Cleaner
I found solution here.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kEwBSAU&l=zh-TW
NI-IMAQdx
The NI-IMAQdx driver software is needed to use third-party image acquisition devices which use the following buses and standards:
