08-27-2020 02:45 PM
We have several firewire AVT camera's with a firewire A interface (AVT Guppy F046B, F503B, Marlin F033C,...)
They are working correctly (on a Windows 7 PC).
However on a brand new Windows 10 install (Pro, 1909, x64), we are having issues :
The Windows device manager recognizes everything fine : PCIe firewire card is recognized as "LSI 1394 OHCI Compliant Host Controller", and the camera is recognized as a "NI-IMAQdx IIDC Digital Camera".
However in MAX, the camera doesn't show up.
We are using IMAQdx 20.0.
What I've tried :
- change the firewire card driver to "1394 OHCI Compliant Host Controller" (without LSI). Doesn't make a difference.
- Install AVT Vimba driver and software. Camera is then working perfectly, but of course not recognized in MAX. So I switched back to IMAQdx drivers.
It seems as Windows is handling firewire differently than under Windows 7. Any ideas please?
Thanks!
Solved! Go to Solution.
08-27-2020 02:50 PM
IMAQdx 20.0 removed support for Firewire cameras, so the latest release of IMAQdx that supports them is 19.5. If you try 19.5 instead, I would expect those cameras to work just fine on Windows 10.
Hope this helps,
Katie
08-28-2020 02:48 AM
Hi Katie,
Thank you for the explanation. Indeed, when I removed IMAQdx 20 and installed IMAQdx 19.5, the camera was immediatly working in NI MAX.
However a new problem popped up : There was no support for LAbVIEW 2020 with the installed IMAQdx 19.5. (Missing .rc files)
Eventually I just solved this by downgrading to LabVIEW 2019.
Now everything is working perfectly.
Thanks for the tip!
Thomas.
