Machine Vision
Loss frames in image aquisition (60-120Hz )
My system has a duo core processor and I´ m having problem to acquiring (60 and 120Hz) and save frame in AVI movie, because frames are lost. I ran the Mltcoreimaqdx.vi  example and the problem minimize but not work so fine. How can I know if two threads are working?
Is it necessary set something in LabView?
(3,532 Views)
Which camera you are using?.... Which version of LabVIEW?...  Its doesn't matter about your PC configuration but you should have a camera with a good frame rate... Post all the details will help us to get you out...
Smiley Wink
(3,464 Views)
Thanks to answear me because Smiley Sad the problem stay alive.
Ok, now I have more information than only configuration of my system, but let´s begin with the configuration:
Labview 8.5 with IMAQdx 3.1.0
My camera it´s a firefly  PTgrey - firewire 400MB and I use the timestamp and frame count information to see the problem.
Now, I did some tests with different approaches and in all cases the results were the same. The loss of frame only happen if the frames are recorded on a real time.
To get in this conclusion I installed a virtual disk (RAM memory) in my computer I recorded in a real time and the frames weren´t lost.
I think that problem happens because the camera and the disk needing the IO bus and during the write operation the IO bus it´s locked to camera. I don´t know it´s the solution, but I would like make a test changing the file size buffer of Vista SO, but I don´t know if it´s possible and how make it.
John
(3,459 Views)
