04-17-2009 06:36 AM
Hi, I'm a newb and I've got a little problem.
I'm processing an image with NI Vision assistant and I'm trying to make a line fit using caliper function.
How does this function works? I mean: the result is an angle and the deviation form the correct fit, but how has the angle been measured?
Thanks a lot
Sofia
04-22-2009 07:39 AM
Hi Sofia,
Please refer to the following post linked below:
It provides a brief but clear description on how the function Caliper works. Tell me if it contains the informations you need and if you need additional support.
Please let me know!
Cheers
