You've just reach a limit, which I admit isn't given, this should be corrected in next version. The solution as you may know is reducing the number of dots, by perhaps calibrating a smaller image,
reducing the field of view (thus increasing the size of the dots and
reducing the number) or using an ROI.
Hope this won't annoy you too much,
