Machine Vision
Is possible to modify camera acquisiton attributes during grab?
Hello, I'm working with IMAQdx , It's possible to modify camera attributes or acquisition attributes during the grab, or it's necessary to close the session , open it again and then modify those attributes?
My idea is to modify things like brightness and to see how the image changes let's say "in real time".
Thanks.
(2,534 Views)
this is absolutely possible. Not all attributes can be modified during a running acquisition, but many of them can and exposure time is certainly one of the most common use-cases.
Try using Vision Acquisition Express to quickly implement this.
Cheers
Birgit
(2,525 Views)
Accepted by Timbk
Timbk,
Check out the Grab and Basic Attributes.vi example in the Example Finder. This example allows you to set attributes while performing the grab.
Jordan
(2,431 Views)
