Machine Vision
Reply
Is it possible to connect GigE camera to CVS
Hi. The GigE and CVS is the only hardware I have available avalable.
Is there any possible way to use these together? And, maybe to connect the cameras through a switch/hub to the CVS's ethernet port?
(967 Views)
No, the CVS does not have a gigabit ethernet port but more importantly its ethernet driver does not support GigE Vision. If you wanted, you could use a supported Axis or Basler IP camera with the CVS through the ethernet port, but the CVS was designed with firewire cameras in mind.
Eric
(953 Views)
