I am trying to get the NI PCIe 1427 card to work with my camera (Uniq Vision UF 1000 ,320x240 at 400 fps). I am using IMAQ driver version 3.8. I am not able to get any images from the camera. I open MAX and select the given camera file for the img0 device. Then I press "Snap" (or "Grab") and see the following message:
Error 0xBFF60022
A timeout error occurred while waiting for the specified event. If waiting for an Image, verify that all video data is acquired within the timeout period. If waiting for a signa, verify that the signal assertion occurs within the timeout period.
Do you have any suggestions on what could be causing this error?
