01-04-2011 07:08 AM
Hello friends,
I am using IR camera with BNC cable. This BNC cable is connected to PC by "Conexant Bt PCI WDM video capture card". So i am little bit confused that how can i use that camera in LabVIEW ?
I am using LabVIEW 8.5.1, LV RT 8.5 , Vision Acquisition's software 8.5 with Vision Development module 8.5
camera - IR camera with BNC cable output
PCI card - Conexant Bt PCI WDM video capture card
so can anyone explain how can i capture image using this camera?
03-09-2011 06:46 AM
Hey,
You will have to contact the manufacturer of this PCI Card for a driver.
The NI Vision Acquisition Software just works with NI framegrabbers, and for sure firewire, usb, gigE and IP Interfaces.
Christian
03-09-2011 07:25 AM
The PCI card with the Conexant chipset is very likely using a driver which should support DirectShow. Assuming your card has proper drivers installed, you have a fairly good likelyhood that it will work with the DirectShow support included with IMAQdx.
Eric
