09-17-2021 11:38 AM
I would like some clarification please.
I try to find a crash/freeze from my CVS 1458RT controller.
I discovered that the physical memory drop to 0 with time. Since I add a protection to reboot the controller if memory is below 500MB, I don't have this crash anymore.
I figured out that this is only when I'm saving the images on the USB drive using the 'IMAQ Write Image fonction'. The physical memory of the controller goes down wherever I save the images. If I delete the files on the USB drive, memory get back ...
I'm a little confused, could anyone help me on this one?
I did a small example attached.
Thank you
Patrick
09-17-2021 01:06 PM
After reading that post :
Look like it's not a memory leak from that imaq function. Memory stabilize at 1% and don't crash. The reboot help me but that's not the root problem.
While trying to find the memory leak, I found that reading a property node ( String[] ) of an enum of only 2 state took 100 ms ... and was slowing down my process. I change it for a case structure and my code is now fast. (weird labview behavior)
I'll see if it help my crash.
thank you.
Patrick
