Machine Vision
Image Control Reference/Property Node and "Create VI" incompatible?
Highlighted
I have encountered this problem a few times already and although I was able to work around it up to now, I'd really like to understand what it is due to:
If I have an image display control on the front panel  (the IMAQ Vision type, not the Picture control) and drop a property node or a reference to it on the Block diagram, it seems impossible to create a subVI from the diagram if the selected objects comprise either an image property node or an image reference. Selecting "Create SubVI" won't don anything, period. No warning message, no system beep, no nothing.
A related issue is that if I have an Image Display control reference on the diagram and try to create a control from it (for instance to use as a control input on a VI connector pane), same thing, "Create Control" won't do anyhting.
Why is that?
Thanks for your feedback.
X.
Message 1 of 10
(3,436 Views)
Highlighted
Accepted by X.
Xavier,
This was reported to R&D (35835) for further investigation. A possible workaround is to make the subVI in LabVIEW 7.1 and open it in the newer version of LabVIEW.
--Michelle
PXI Software R&D
PXI
Machine Vision
Message 2 of 10
(3,399 Views)
Highlighted
Still pending in LV 2013 SP1. Any chance that has been fixed in LV 2015?
Message 3 of 10
(2,773 Views)
Highlighted
/bump
Not fixed in LV2014 atleast. Hopefully in 2015 but would not believe so.
However as a work around I pass the reference around as a variant instead (that works)
Message 4 of 10
(2,549 Views)
Highlighted
Nope, still well and alive in LV 2015.
Message 5 of 10
(2,537 Views)
Highlighted
will you do solve this poblem? it is really a big necessity.
Message 6 of 10
(2,325 Views)
Highlighted
It has been introduced in LV 8 (if I understand Michelle_N's answer of 8+ years ago) and is still not fixed in LV 2016. What's your bet?
Message 7 of 10
(2,322 Views)
Highlighted
Thanks X.
I was pulling my hair out bundling all my controls references together and it would not allow me to create a control.
Luckily my Image control was the last in the Bundle and the first one I removed then control creation worked.
Googled and your post was at the top of the heap and now I know why (LabVIEW 2015).
-AK2DM
Message 8 of 10
(1,022 Views)
Highlighted
Hi.
You don't need to install LV7.1 and create new VI and transform to new version of LV.
Use Type Cast function to convert vision image reference to U32 number, wire to subVI by connector pane, and use Type Cast to reference back. See image below.
Message 9 of 10
(730 Views)
Highlighted
An easy method is to create the reference to the image display (in the block diagram), then drag the reference from the block diagram to the front panel. The reference control will appear there.
Message 10 of 10
(276 Views)
