Machine Vision
Image Control Reference/Property Node and "Create VI" incompatible?
I have encountered this problem a few times already and although I was able to work around it up to now, I'd really like to understand what it is due to:
If I have an image display control on the front panel  (the IMAQ Vision type, not the Picture control) and drop a property node or a reference to it on the Block diagram, it seems impossible to create a subVI from the diagram if the selected objects comprise either an image property node or an image reference. Selecting "Create SubVI" won't don anything, period. No warning message, no system beep, no nothing.
A related issue is that if I have an Image Display control reference on the diagram and try to create a control from it (for instance to use as a control input on a VI connector pane), same thing, "Create Control" won't do anyhting.
Why is that?
Thanks for your feedback.
X.
Message 1 of 8
(2,587 Views)
Accepted by topic author X.
08-27-2015 04:09 PM
Xavier,
This was reported to R&D (35835) for further investigation. A possible workaround is to make the subVI in LabVIEW 7.1 and open it in the newer version of LabVIEW.
--Michelle
PXI Software R&D
PXI
Machine Vision
Message 2 of 8
(2,550 Views)
Highlighted
Still pending in LV 2013 SP1. Any chance that has been fixed in LV 2015?
Message 3 of 8
(1,924 Views)
/bump
Not fixed in LV2014 atleast. Hopefully in 2015 but would not believe so.
However as a work around I pass the reference around as a variant instead (that works)
Message 4 of 8
(1,700 Views)
Nope, still well and alive in LV 2015.
Message 5 of 8
(1,688 Views)
will you do solve this poblem? it is really a big necessity.
Message 6 of 8
(1,476 Views)
It has been introduced in LV 8 (if I understand Michelle_N's answer of 8+ years ago) and is still not fixed in LV 2016. What's your bet?
Message 7 of 8
(1,473 Views)
Thanks X.
I was pulling my hair out bundling all my controls references together and it would not allow me to create a control.
Luckily my Image control was the last in the Bundle and the first one I removed then control creation worked.
Googled and your post was at the top of the heap and now I know why (LabVIEW 2015).
-AK2DM
Message 8 of 8
(173 Views)
