I have an IP camera streaming JPEG-compressed images. I tried to use IMAQdx Get Image Data.vi to get the raw bytes and save it to disk, but I can't produce a valid JPEG file.
In the code below, test2.jpg is always a valid JPEG file around 69 KB, while test1.jpg is always an invalid file around 65 KB (I tried both big-endian and little-endian settings, with the same results).
Any ideas?
