Machine Vision
IMAQdx and the use of Python wrapper pynivison
Hello -  I have a NI PCIe 1427 frame grabber with IMAQdx installed.  NI MAX sees the frame grabber and I can snap or grab images fine from the camera I'm using, a Xenics Bobcat 320.  I need to use python 3.5 to grab images from the frame grabber and I found a python wrapper, pynivision:  https://github.com/robotpy/pynivision
When I try to opening the camera using:  IMAQdxOpenCamera I keep getting a error:  ctypes.ArgumentError: argument 1: <class 'TypeError'>: wrong type
I'm not a newbi to Labview and Machine Vision but am a newbie to python.  Has anyone successfully used pynivision?
This is the simple example I'm running:
import core as nivision
import sys
name = "img0"
id = nivision.IMAQdxOpenCamera(name, nivision.IMAQdxCameraControlModeController)
pic = nivision.IMAQdxGrab(id)
closeCam = nivision.IMAQdxCloseCamera(name)
 import core is part of the pyniwrapper that defines all the IMAQ functions.
Thank you for any help.
(1,630 Views)
Accepted by topic author hwGuy
The 1427 uses IMAQ, not IMAQdx, and thus will not work with that Python wrapper.
(1,589 Views)
Thanks BlueCheese, big oversite on my part.  Now back to the drawing board.  I'm guessing just removing the 'dx' in the api won't work with IMAQ.
(1,577 Views)
Did you finally solved this issue?
I am trying to connect also a NI frame gabber(1433) with Python but i guess it is also IMAQ
(458 Views)
