05-22-2017 05:13 PM
I am using a Mightex USB camera for image acquisition and after installing the DirectShow driver provided by the manufacturer, I'm attempting to use it in LabView. When I use the camera in MAX, the camera works as I expect it to, but using the OpenCamera VI for IMAQdx in my VI immediately raises an unspecified error.
I'm running 32-bit LabView, and my versions of LabView, MAX, and IMAQdx are all 16.0. I installed the DirectShow driver for 32-bit applications and since it works in MAX, which I've heard is 32-bit, I'm pretty confused as to why it isn't working in my VI. Any suggestions?
Solved! Go to Solution.
05-23-2017 12:44 AM
-Do you have Development Support installed?(Check in NI MAX Under Software->NI-IMAQdx)
-Any other cameras you tried with the PC before?
-Post the Code and Exact Screenshot of the error dialog.
-Try re-installing the drivers(IMAQdx and Directshow).
05-23-2017 12:49 AM
Thanks for the reply. After spending almost two hours trying to ferret out the problem, simply restarting my PC made it work like I expected it to. I imagine there's something a little finicky about the DirectShow driver for the camera, as I have used other cameras on the same computer with the exact same application previously and had no problems.
