Machine Vision
IMAQdx: Error -2147467259 Unspecified error at Open Camera VI, but camera works in MAX
I am using a Mightex USB camera for image acquisition and after installing the DirectShow driver provided by the manufacturer, I'm attempting to use it in LabView. When I use the camera in MAX, the camera works as I expect it to, but using the OpenCamera VI for IMAQdx in my VI immediately raises an unspecified error.
I'm running 32-bit LabView, and my versions of LabView, MAX, and IMAQdx are all 16.0. I installed the DirectShow driver for 32-bit applications and since it works in MAX, which I've heard is 32-bit, I'm pretty confused as to why it isn't working in my VI. Any suggestions?
(2,706 Views)
Accepted by topic author siq877
-Do you have Development Support installed?(Check in NI MAX Under Software->NI-IMAQdx)
-Any other cameras you tried with the PC before?
-Post the Code and Exact Screenshot of the error dialog.
-Try re-installing the drivers(IMAQdx and Directshow).
uday
(2,663 Views)
Thanks for the reply. After spending almost two hours trying to ferret out the problem, simply restarting my PC made it work like I expected it to. I imagine there's something a little finicky about the DirectShow driver for the camera, as I have used other cameras on the same computer with the exact same application previously and had no problems.
(2,659 Views)
