Machine Vision
I would like to use my IMAQ Hardware for streaming data to disk. The available support is only for C, but I need a Delphi/Pascal interface. Has anyone programmed an ActiveX component or an import library?
I made an ActiveX Library (in Borland C++ Builder) for using the imaq functions.
I can send it to you.
But I think if you are using Delphi you could
use packages (.bpl)
My email -> frank3025@yahoo.com
(3,040 Views)
