Machine Vision
I want a thicker overlay line using oval overlay
I have added a oval overlay to an image. It seems that the line is only one pixel wide. I need a thicker line, e. g. 3 pixel to enhance visibility of the oval.
I used three oval overlays which have a wider rectangle each. This results in a thicker line, but is there a more elegant solution. The oval overlay function does not have a parameter for this.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,657 Views)
Hi Waldemar,
try the vi i've posted here
http://forums.ni.com/ni/board/message?board.id=200&message.id=17125&jump=true
Regards, David
(2,638 Views)
