Machine Vision
Reply
How to pass and reject a nut ( particular dimension) using particle analysis. ?
Hello.
         My task is -
If I have nuts of  different diameter (say 1 cm, 2 cm ) , I have to pass 1 cm nut and all the other nuts are rejected.
Can I use particle analysis for this ?
As I am new in NI Vision ,Please suggest me appropriate steps to proceed.
Thanks !
(2,986 Views)
Accepted by topic author shreya111
08-27-2015 04:09 PM
Re: How to pass and reject a nut ( particular dimension) using particle analysis. ?
Yes, you can...
Select appropriate particle measurement you need and filter using particle filter.
for details on which particle measurement need to be used please refer:
http://zone.ni.com/reference/en-XX/help/372916P-01/nivisionconcepts/particle_measurements/
-I hope you are aware of the fact, you need to calibrate if you want real world measurements.
uday
(2,953 Views)
          I made a VI , It sometimes show area(pixels) of 3 particles and sometimes more than 3 particles. I am attaching my vi and respected snapshots. Is I am going on right track ? Please suggest me modifications as soon as possible.
(2,931 Views)
-You are on right track...
-Depending on your requirement you need to tighten filter parameters, by adjusting parameters you can filter required particles only.
-Which filter parameter you are using to filter particles and why?
-Which particle is required to separate from the other in the image?
uday
(2,906 Views)
          Suppose I have 3 nuts having diameter 0.6 cm, 0.8 cm and 1 cm respectively. I want to pass 1 cm nut and reject other ones with the help of their areas using particle analysis and it should also show its area on front panel.
I  chose Heywood Circularity factor in particle filter 3 vi and Heywood Circularity factor, Center of mass X and Area in Particle Analysis vi.
The problem is , it sometimes accept another particles when I move the nut on another places .
I am attaching my VI and respected snapshot. Please give me valuable suggestions.
Waiting for favorable reply.
(2,867 Views)
Highlighted
Hi Sir,
My case is more or less the same, use the vision to capture whether the screw nut is there.
So follow the same way ?
By the way, open CV and labview is more or less identical ? or be used in different field ?
Thanks.
Bruce
(42 Views)
