11-12-2014 12:27 AM
Hello.
My task is -
If I have nuts of different diameter (say 1 cm, 2 cm ) , I have to pass 1 cm nut and all the other nuts are rejected.
Can I use particle analysis for this ?
As I am new in NI Vision ,Please suggest me appropriate steps to proceed.
Thanks !
11-14-2014 01:05 AM
11-15-2014 12:38 AM
I made a VI , It sometimes show area(pixels) of 3 particles and sometimes more than 3 particles. I am attaching my vi and respected snapshots. Is I am going on right track ? Please suggest me modifications as soon as possible.
11-16-2014 11:04 PM
11-20-2014 05:18 AM
Suppose I have 3 nuts having diameter 0.6 cm, 0.8 cm and 1 cm respectively. I want to pass 1 cm nut and reject other ones with the help of their areas using particle analysis and it should also show its area on front panel.
I chose Heywood Circularity factor in particle filter 3 vi and Heywood Circularity factor, Center of mass X and Area in Particle Analysis vi.
The problem is , it sometimes accept another particles when I move the nut on another places .
I am attaching my VI and respected snapshot. Please give me valuable suggestions.
Waiting for favorable reply.
01-12-2019 01:53 AM
Hi Sir,
My case is more or less the same, use the vision to capture whether the screw nut is there.
So follow the same way ?
By the way, open CV and labview is more or less identical ? or be used in different field ?
Thanks.
Bruce
