Machine Vision
How to overlay transparent bitmap on imageViewer image
I am using NI Vision Dev module 2012 SP1 with Visual Basic 2010 Express. I want to overlay a transparent bitmap over an image on ImageViewer object.  Earlier I found reference which addressed this task quite well, but I foolishly lost boookmark and I've looked all over and can no longer find it. Can someone help me?
(5,667 Views)
Hi philgo,
You would want to use the IMAQ Overlay Bitmap VI to accomplish this. I found a general example that shows how this VI can be used, as well as an example that deals specifically with transparency. I hope this helps!
David S.
(5,647 Views)
Hey! i am Christorpher.  i use the NI IMAQDX to get one image to the variable(done),but i do not how to display this image to the imageviewer. Because i need to get a lots of images when the machine is running and after running i need to process every single one imag in the array and want to show the result in the imageviewer! Can you guys help me to solve this problem?  Thank you!
(5,545 Views)
What exactly are you wanting the result in the image viewer to be (just one image at a time or the whole array of images)? Also, I would recommend posting this question as a new thread in the Measurement Studio forums. Posting a new thread will open up your question to even more users and therefore have a better chance of having an ongoing discussion with multiple users. The forums for Measurement Studio can be found at the following links:
http://forums.ni.com/t5/Measurement-Studio-for-NET/bd-p/232
http://forums.ni.com/t5/Measurement-Studio-for-VB6/bd-p/230
http://forums.ni.com/t5/Measurement-Studio-for-VC/bd-p/231
dK
(5,523 Views)
