Machine Vision
How to handle 4 line scan alanog camera with PXI
I'm installing about line scan system.
But I'm trouble that system.
handleing part : PXI-8176
OS : window 2000
Line scan camera x 4ea (perkin
elmer: LC3023PGN-022)
PXI-1409 x4ea
I would like to multiple ring acquisition using attach file.
I set 2048x500(H x V)of image size in max.
I wondering that the one of the 4 "last valid buffers" stops during running and display also doesn't act. after 10 minutes, all buffers stop.
How can I solve this problem?
Give me some information.
How can I
(3,326 Views)
The VI you attached had only 3 different cameras to acquire from - you may want to make sure that you are only trying to acquire from the correct 3.
Also, you may want to make a separate camera file for each of the cameras since they are the same type. This document explains how to do that:
http://digital.ni.com/public.nsf/websearch/F9235C5B145580AD86256C3A00716A26
You may also want to try acquiring from just 2 cameras at first and see if that works, then add on more after that.
Hope this helps-
Julie
(3,326 Views)
thank you for answering.
but you said that I think in case of different camera setting.
I tested it of seeing your link page.
but the situation is same.
I'd like to know why image buffer count and display has stopped.
I don't know maybe image data amounts is too big.
Please if you have more imformation, inform me
Thank you. Have a nice day
(3,326 Views)
Have you tried acquiring a smaller image size? If the error no longer occurs, than that is definitely the issue.
(3,326 Views)
