Machine Vision
How to calculate perimeter of individual particles?
Hi everyone,
I currently have a VI which takes an image, converts it into binary, and then runs it through particle analysis.
However, I can not figure out how to calculate the perimeter of each particle.
I want to use the total perimeter of the particles to compare two images.
Any help would be appreciated,
John
(5,036 Views)
consider using "IMAQ Particle Analysis" instead of "IMAQ Particle Analysis Report":
The output of the above should be 1 column, n rows, where n is the number of the particles.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,021 Views)
I appreciate the help!
(4,981 Views)
      Can you please send your vi in labview 2012 version.
Thanks .
(4,251 Views)
