11-24-2017 03:40 AM
Hello Sir,
I interfaced FLIR A625 camera with LabVIEW and want to find Min, Max and True Value of ROI specified in the image. Please help me out.
Thank You.
11-24-2017 05:27 AM
@ArunM wrote:
Hello Sir,
Thank You.
Publish what you have done so far and I can see if I can help you. Have you opened the included toolkit examples?
11-27-2017 08:53 AM
Are you able to acquire from the camera? If so, you can use the IMAQ functions.
12-07-2017 06:16 AM
No Sir Not Yet, ill be getting Toolkit DVD by this Weekend
12-07-2017 06:19 AM
I'm able to acquire image but which functions should i use to analyze the ROI of Image? If you have any sample VIs please share it to me.
Thank You
12-07-2017 07:05 AM
If I remember correctly, A625 has measuring functions; i.e. ROI can be analised at camera side.
So, you have two options:
1. Engage camera measuring function. Three examples are supplied with ThermoVision LabVIEW Toolkit.
2. Obtain 2D temperature array from temperature image using IMAQ ImageToArray and implement own algorithms.
12-22-2017 05:12 AM
Sir, as im running the Example VI included in Thermovision Toolkit at the Open Thermovision VI I GET a pop up to select a camera. How should i eliminate it and connect it to my camera?
12-22-2017 05:48 AM
You shall set fixed IP in your camera. Then provide this IP as string to the example VI. I do not remember name of the input field and have no Toolkit in this computer. However, if you open one of simple examples, this will be the only input of String type. Write the camera IP in form 123.456.789.012 avoiding any spaces.
12-26-2017 06:16 AM
Sir i have attached the invoke node which gives the pop. Please revert me soon.
12-27-2017 10:07 AM
Hi ArunM,
You can differentiate between datatypes in LabVIEW, either by pressing CTRL-H and hovering over the input, or by looking at the color. Using the information in this article, you should be able to find the String input that _Y_ was referring to, and from there can follow his instructions regarding the IP address.
