05-03-2012 11:36 AM
05-04-2012 02:50 PM
If you cannot communicate on low-level TCP/IP with this camera, you might want to ask them if there's any interface that can be used. Ask them about Ethernet, USB, FireWire, Serial, anything. Once you find that out, then you can ask whether that same interface will work with LabVIEW (most of the time the answer is yes, it's just a hard task to do a lot of the low-level organization of data into image data).
05-18-2012 08:05 AM
Hi ulfn ,
If i buy the Flir toolkit what are features they provide .Do they give and special vi consisting of algorithm for image processing or its just going to grab the image and displaying .
05-18-2012 08:30 AM
05-18-2012 08:59 AM
Hi ulfn
Thanks . so ill get an GIGE camera in which i can do these thing using the IMAQ dx .
07-22-2012 04:29 AM
Hey everybody,
I was finding solution for my problem, and looked your discussion, seems like you ppl could solve my problem. I am workng with FLIR A40 cam with labview. I was tring to read the temp image in the labview by the examples given in the labview toolkit. But I am getting an error as "Error -1 occured at Thermovision open.vi Failed to connect camera. Error code#1,Device not present", But i can identify the cam in MAX and view the video in it, but while running the labview coding, its giving me the error. Do anybody know the solution. Pls let me know ASAP as I my project deadline is near.
07-22-2012 01:39 PM
07-22-2012 02:05 PM
Hi Ulfn,
Thanks for replying me. The cam is connected to the PC through firewire1395. I have entered all the cam name, connection port and the serial number of the cam shown in MAX correctly, but still I get the error. What is the active x mean? the cam shows up under Imaqdq in MAX devices and interface, but in the labview examples, eventhough if i enter al the parameters, its showing error. And where should I click connect in active x?
07-22-2012 02:35 PM
07-22-2012 05:46 PM
sorry, I could not get you clearly. I opened the thermovision examples installed in the labview folder and I could not find the active x control. If i open anyone example it opens the front panel of it.
