The calibration information is saved as Vision Information. Once you have calibrated an image, save it to disk using WriteImageAndVisionInfo. In your other program you can load this image using ReadImageAndVisionInfo. To calibrate a new image, simply call SetCalibrationInformation. It is important to note that both images must be the same size.
