06-17-2011 09:59 AM
After doing some searching it seems that I could be victim to the whole U16 acquire/display issue that I have noticed mentioned in heated discussion in other forums. The camera that I am using is 12 bit monochrome and outputs to a U16 array. I am using labview 2009 with the VDM eval.
It was mentioned previously that this could be an alignment issue. I have also heard nothing good about dealing with U16 image data. I tried the U16 to I16 conversion of the 2D array made with Image to Array but that didn't yield any image at all in the intensity graph. You can see the Intensity Graph as well as Image Display in the attatched capture. Any recommendations on getting the image to display correctly?
06-17-2011 10:18 AM
You can create either I16 or U16 images to pass to your DLL, depending on what datatype it is expecting and what format you wish to process in. If your camera DLL is only putting data in the least-significant bits then there is no difference between a U16 and I16 and you could use them interchangably.
Eric
06-17-2011 10:37 AM
Unfortunately changing from a U16 to I16 in IMAQ create and the type coming from Image to Array didn't change the way the Intensity Graph nor Image Dispaly looked. Perhaps I should look at the pixel values and see what I am really dealing with? That would be a huge array though and I think the IMAQ still won't let me see the alignment values.
Is the Image array and 2D array from ImagetoArray the raw data that was read from the camera? It doesn't get changed until the Intensity Graph or Image Display go to display it, correct? Thanks!
02-18-2018 11:24 PM - edited 02-18-2018 11:26 PM
If you change the border size of 'IMAQ Create VI' to 0, the problem will be solved.
