Machine Vision
How do I get the EVS-1464 to recognize a compact flash card with the realtime OS
I'm using the EVS-1464 and want to write data to the compact flash card.  The manual says that if running a Windows OS it should show up as a new drive...but what if I'm running the real time OS?  How do I access the drive?
(3,519 Views)
I will look into this and get back to you soon.
Vivek Nath
Machine Vision
(3,493 Views)
You should be able to just access it in a similar fashion to what is mentioned in this article: http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/d400b408d9e2d4aa86256bc3007faa55?O... .
Although it does not refer to the EVS, you should be able to ftp into the compact flash drive by referring to the correct drive letter. Let me know if you have any trouble with this. If so, please let us know what you have tried and what exactly you observed.
Vivek Nath
Machine Vision
(3,482 Views)
