10-22-2009 12:34 PM
I have two cameras (JAI - CV-M4+CL) and I would like to take two simultaneous images from them by a NI PCIe 1430 board using a external trigger. Is that possible? Is there another kind of solution for my problem? What I need is just two synchronized images aquisition!!!
regards
10-22-2009 12:44 PM
Yes, the 1430 has two completely independent acquisition engines that can acquire separate or simultaneously. You'd likely want to use some sort of trigger to trigger both cameras simultaneously since the cameras themselves would not be in sync otherwise. You could use the IMAQ board itself to generate a trigger if you like.
Eric
10-22-2009 03:29 PM
Hi, Eric
Thank you. I want to trigger (simultaneously) my two cameras by one trigger signal at SMB Trigger Connector of PCIe-1430, is it possible?
Regards.
04-10-2011 10:17 AM
I have a pcie 1430 grab card and a silicon imaging 1300MH_CL camera , I want to trigger each image continuously ,
the camera have a trigger line itself ,and the CC1 is said to trigger the camera ,which one to use ,
I should use pulse from another machine ,how to link the trigger , from the SMB on the grab card , or something else?
04-13-2011 03:09 PM
Hi brunomarangoni,
To get your two boards to trigger at the same is pretty easy.
