Machine Vision
How Do I perform a Live Update using property node for a IMAQ front panel indicator?
Where are the examples for using the new property nodes? How does one instigate an update of the display - especially after ROI functions?
(3,847 Views)
To do an update of a displayed image on the new front panel image display, you can use an Invoke Node and select Refresh Image.
Bruce
Bruce Ammons
Ammons Engineering
(3,847 Views)
Bruce,
I've heard that not all the property nodes work in vision 7.0 -such as the "Value" Property.
(3,847 Views)
I'm not sure about any details regarding that, but I am pretty sure this Invoke Node works pretty well. I have used it several times.
Bruce
Bruce Ammons
Ammons Engineering
(3,847 Views)
It is true that the Value property will give an error if you try updating it in Vision 7.0 - this will be fixed in the next version of the software.
In the meantime, the workaround is to use a global variable to pass images from one VI to another instead of the property node. Using a global variable works, but not in the same way as a reference or property node would. With a reference or property node, you can pass a reference of the control to a subVI and have the subVI update the control's image. Using global variables, the subVI will update the global variable with the new images, but you need a loop monitoring the global variable in your top level VI.
Hope this helps-
Julie S
Applications Engineer
(3,847 Views)
Does the "Method Property - Update" Work? Could I not pass the IMAQ Image reference to the modifying vi - like draw ROI rectangle - then call the "refresh" method?
(3,847 Views)
Yes - that should work. The situation I was referring to was if you were trying to update an image from a subVI.
(3,847 Views)
