Machine Vision
Hi, I am facing hunging problem in Labview 8.2, Vision Assistant 8.0
Hi, I am facing hanging problem in Labview 8.2. Actually I am executing the NI VISION based application with some basic function like Color thresholding, blob analysys and Pattern matching. I feel problem is due to some function of Vision. Because once I am loading a VI, which is having most of the function related to Vision, then hanging problem drastically increasing. Pls suggest the solution
Regards...
Mahar
(2,685 Views)
Are you generating the vi from vision assistant? Can you post a screens shot?
(2,684 Views)
