Machine Vision
Grabber card NI 1427 TTL trigger from encoder input
I am using the 1427 grabber card.
I have the following setup, and I have failed to make the correct configuration in the NIMAX 18+.
  1. Encoder signal input from a servo amplifier.
  2. NI 1427 Grabber card should make a division on the signal
  3. The grabber card should generate a trigger on TTL_TRIG(0) pin, with this divided signal.
  4. This TTL signal should trigger a Line camera's line-trigger input.
Please guide me how to make this configuration in NI MAX 18.
Thank You, and BR.
Message 1 of 1
(1,725 Views)
