Machine Vision
Gige vision camera fails with trigger on
i have gige vision camera sca640-70gc and when i set the trigger mode on it gives fail with line1 and line2 while with trigger mode off it works ok
(3,534 Views)
Do you provide a trigger signal on the dedicated input line of your camera such as a TTL signal?
Regards
(3,530 Views)
Yes i do. and tried both direct trigger from the PLC and terminal block as well and it gives same result(fail)
(3,513 Views)
Hi Frank,
Is your camera triggers works in pylon viewer?
Silver_Shaper | CLD
(3,507 Views)
