12-05-2011 08:50 AM
GigE VIsion Camera IP and Port setting in multicast mode (IMAQdx)
Hello, Everybody
I have NI-IMAQdx 3.5.0 , and I have Basler Camera (scA640-74gc) with GigE Vision Interface.
I run that camera in my computer as controller (Multicasting mode) with IP (239.192.0.1)
I detected that camera in another computer (to run it as listener) by LbVIEW .
my problem is
I run the Pylon Viewer from Basler (Monitor mode) after I detected that camera.
it was run successfully (I look to details of that camera it have same IP 239.192.0.1 and the port changed every time when i stop running in controller computer)
from where i can set fixed Port in multicasting mode??????
When I use Pylon Viewer in controlled computer and set the mode to multicast
I should set IP and port , then in listener computer I run Pylone Viewer (monitor mode) I saw same IP and same port which i set it in controller
I need a way in LabVIEW to set Port Number in multicasting mode...How I can do that
Best Regard
Alzhrani
12-05-2011 10:45 AM
Hi Alzhrani,
There is currently no way in IMAQdx to fix a specific UDP port used for multicasting. Since the listeners/monitors can query the port number from the camera, IMAQdx always queries this directly rather than assuming it is at a fixed value.
Eric
12-08-2011 12:28 PM
Thankyou Eric
I have no problems if my programes based in LabVIEW (IMAQdx) in both computers (Controllers and Listener)
but when I built a program based in LabVIEW in controller computer and in other computer (Listener) based in C++ ,
How may I know the multicasing port in listener?
Best wishes
Alzhrani
12-08-2011 02:26 PM
Hi Alzhrani,
Unfortunately it is a bit more complicated because you would have to use the GVCP protocol and do a register read of a specific register on the camera that stores the multicast UDP port (that IMAQdx programs from the controller). However, this likely requires access to the GigE Vision specification in order to be able to format the messages correctly.
Eric
