Machine Vision
Get last frame of an image
So have a case in the first while (where I take images each 0.5sec) which I have to take the last image if I press a button.
And in the other case (where I display the last image) just obtein the image and dequeue it? here in this while I do not need a case right?
Thanks a lot again!!!!
Message 11 of 15
(1,419 Views)
Yes, in second loop you don't need case.
Only way to thank is by giving kudos:)
uday
Message 12 of 15
(1,418 Views)
Thanks!
When I arrive at home I will probe that!
Message 13 of 15
(1,416 Views)
I think you need some thing like that
test this example vi
and tell if iy could solve your problem
Message 14 of 15
(1,399 Views)
and tell if it could solve your problem
Message 15 of 15
(1,399 Views)
