09-24-2013 01:20 PM
I am using a PCIe 1427 frame grabber to capture images from a linear CCD camera.
In the MEA, I can the synchromization to "Free Run" and the "signal levels" panel as that in the below figure. The card has a 15 pin D-SUB connector and I connected a signal cable to the pin 1 and 9 in order to reach the External Trigger 0. However, I did not see the trigger TTL signal output.
09-25-2013 03:15 AM
You must use IMAQ trigger route to route trigger from one line to another.
09-25-2013 03:31 AM
Hi, Kate,
Thanks a lot!
I am wondering if it is possible to set the trigger from the frame grabber in the IMAQ.
Do you have an example for that?
09-26-2013 03:25 AM
Hello Ling_Wang,
Where is your trigger signal coming from?
Is it an external trigger signal.
If yes, then you should be able to use the following method:
http://digital.ni.com/public.nsf/allkb/38E46AE6989321EA8625799F0061832B?OpenDocument
If your trigger signal is coming from somewhere else, then please explain a bit more in detail how your complete system looks like.
09-26-2013 04:00 AM
Hi, Thierry
Thanks a lot! Yes, I understand to trigger the camera using an external source.
however, I prefer to use the inner trigger from the frame grabber (or the camera), so that I can set the camera to run with the highest speed.
09-26-2013 07:06 AM
Hey,
I think this is the document you're looking for:
http://digital.ni.com/public.nsf/allkb/4FC0695C6489E11C8625716A0024AF4D?OpenDocument
