08-03-2011 09:07 AM
I'm a green hand in labview. I tried to control my camera (Dalsa, Falcon 1.4M100) by the labview with the camera link frame grabber (Dalsa, Xcelera-CL LX1 Base). I have the VisionAcq850. But I can not find it in the MAX as attached. Should I write some configure files (such as dll files) by myself or I can not use it.
Solved! Go to Solution.
08-03-2011 10:32 AM - last edited on 04-18-2024 08:46 AM by Content Cleaner
No chance. MAX will not recongnize third party camera link framegrabbers.
The following workarounds for you:
- use NI PCI 1426/1428 CL grabber - this is easiest way
- use camera with GigE or firewire interface
- use Xcelera-CL API for programming - this is most hard way (not recommended for beginners)
Andrey.
08-03-2011 10:44 AM
Thanks!
I have to choose the third way, or my boss will be unhappy for the extra thousands of dollars
