07-14-2009 12:47 PM - edited 07-14-2009 12:48 PM
^ Thanks for the suggestion. I tried it, but still have the same problem. For reference, here's what the VI looked like:
It it makes a difference, I'm useing the ThorLabs DCU223M camera:
http://www.thorlabs.com/NewGroupPage9.cfm?ObjectGroup_ID=2916
07-14-2009 01:00 PM
Ok, here's something wierd. I changed the camera index from 1 to 0, and it worked repeatedly, but the image was inverted ... ? So I flipped it back and everything seems to be working for now. I need to integrate it to the other VI to make sure, but here's what the working test setup looked like:
07-15-2009 09:12 AM
I'm not surprised you had to set the index to zero. I had to set mine to one because a Firewire camera showed up as the first camera in the list.
As for the inverted image, I have never seen that before.
07-15-2009 09:19 AM
^ Thanks for your help. Using your suggestions, I got this thing to work finally. I integrated the changes into the orginal project and everything works like a charm.
Thanks again,
-Tom
