06-07-2016 07:41 AM
I am working on a program which aims to detect cracks with Vision Assiatant.My target is to get the cracks only after a series of operation,but there are three round edges that I can't eliminate them.I have uploaded the original images and script file.Does any of you can afford me with a few advice to eliminate the round edges?
Looking forward to your reply!
06-18-2016 12:28 AM
06-21-2016 03:31 AM
When I just started doing this project,I tried Texture Detection.I spent enough time on this method,But the results were not ideal.Could you please give me some improvements?
06-21-2016 04:54 AM
06-21-2016 05:06 AM
indeed your fist step problem is your lighting system
you have to change it
check this link http://www.ni.com/white-paper/6902/en/
after that you can use some morphology function for improve crack feature and then you can solve your problem
06-21-2016 07:40 AM
06-21-2016 08:44 PM
OK,I will.Thank you very much!
06-24-2016 02:17 AM
I have tried your method,but it can only detect its edges and overlook the crack completely.The results are attached,could you please make some improvements?Thank you very much!
06-24-2016 04:11 AM
06-24-2016 07:52 AM
