Machine Vision
Does any of the NI boards support Dalsa Eclipse TDI camera?
Does any of the NI boards support Dalsa Eclipse TDI camera? The camera has 512 Pixels and LVDS output.
AM
(3,597 Views)
Hi AM,
The NI 1424, which is a parallel digital board, supports a LVDS output. Does the output of the camera conform to the CameraLink standards? If so, there are 5 different boards that you could use. To determine which of the CameraLink boards to use, it will depend on whether the camera use a base, medium or full configuration. As well, it will depend on how many trigger lines you want to use.
Message Edited by O54E on 01-04-2010 11:03 AM
(3,576 Views)
