Machine Vision
Control exposure time and gain with FPGA as frame grabber
I have found this code where I believe something similar is done.
https://decibel.ni.com/content/docs/DOC-5049
The main difference is that as I am using RIO, IMAQ cannot be used, so it should be converted to VISA, as pointed out in the last post of this forum:
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/My-Basler-acA2040-180km-NIR-is-not-visible-in...
Anyone knows how to do this?
I understand this VI should be built in the code in so that the SerialServer can access it in order to control the camera,
Is this correct?
Message 11 of 12
(2,280 Views)
Try working off the example located in the LabVIEW example finder located at Hardware Input and Output>>Vision Acquisition>>Vision-RIO>>NI 1473R>>1-Tap 10-Bit. There's a white loop all the way to the right of the block diagram that has the necessary code to communicate serially with the 1473R.
Mike
Message 12 of 12
(2,173 Views)
