01-21-2010 07:18 AM
01-21-2010 11:33 AM
Hi Bert,
It means the camera file just contains enough functionality to allow the framegrabber to know how to acquire the image data, not how to control all the features on the camera. You will have to run the Basler Pylon utility to change any settings within the camera itself and then you can save those settings into the camera. Then when you acquire in IMAQ, the camera will use those settings you configured in Pylon.
Note that if you still want to control some features dynamically from LabVIEW you can still send serial commands directly with the IMAQ API. You just need to make the commands match the format that Basler describes in their manual.
Eric
