09-06-2021 02:41 AM
I am trying to create a rectangle overlay(preferably red), therefore I am using "IMAQ Overlay Rectangle" tool. But the overlay is nondestructive so I needed to use "IMAQ Merge Overlay" to overwrite on the image. However, after this tool output image is getting RGB format. I need grayscale image. Is there any way to overwrite colorful rectangle on the grayscale image. Thanks in advance, every suggestion is appreciated.
09-06-2021 09:43 AM
A grayscale image does not have any color. The only way to add color is to convert it to a RGB image. There is no way around it.
Bruce
09-07-2021 04:19 AM
Thank you for the information. I thought maybe there is a build function for this but apparently there is no. Thanks.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
